TWX: Sending email content as iterated infotable data in html table format
VaibhavShinde
Hi ,
I am looking for sending Infotable data as body part of mail in html table format , but I am getting overwritten data while iterating. please see below code and screenshots too.
var result = me.getDataForWeek(); //infotable result
var tableLength = result.rows.length;
for (var x=0; x < tableLength; x++) {
var row = result.rows[x];
var rowvalue1= row.M_Key;
var rowvalue2 = row.PowerFactor;
var emailContent = "<html><body>\
<table>\
<tr><td>M_Key</td><td>Powerfactor</td></tr>\
<tr><td>"+rowvalue1+"</td><td>"+rowvalue2+"</td></tr>\
</table></body></html>"
Things["EMS_MailThing"].SendMessageWithAttachment({
to: " abcd@gmail.com" /* STRING */,
cc: undefined /* STRING */,
bcc: undefined /* STRING */,
subject:"Mail with table content" /* STRING */,
//content : emailContent,
body: emailContent /* HTML */,
infotable result:
key location source sourceType tags timestamp M_Key M_Description ApparentPower ConsumedPower PowerFactor Date
5.0 0, 0, 0 EMS_DataTable Thing
Data Tag not selected
2020-02-03 08:09:03
5
undefined
300
200
0.8
undefined
7.0 0, 0, 0 EMS_DataTable Thing
2020-02-04 06:39:39
7
undefined
340
260
0.9
undefin
output I am getting for current code is:
M_Key
Powerfactor
7
0.9
Thank you
1 ACCEPTED SOLUTION
Please add semicolon after variable declaration.
Please see below how it should look:
var emailContent="<html><body><table>";
emailContent =emailContent+"<tr><td>M_Key</td><td>Powerfactor</td></tr><tr><td>"+rowvalue1+"</td><td>"+rowvalue2+"</td></tr>";
emailContent=emailContent+ "</table></body></html>";
logger.warn(emailContent);
I have added a logger.warn to write the string html in the log for troubleshooting.
Hope it helps,
Raluca Edu
6 REPLIES 6
I think that based on what you wrote you would want a single email with the two rows.
The error is the following: in the loop you declare a variable called emailContent. Each time you execute the loop you overwrite that variable, instead of adding to it.
try googling on how to print html table through loops in javascripts.
it would be somewhat similar to // here for loop would be replaced by yours
var i = 0;
for (i=0;i<=10;i++){
document.write("<table width=50 border=1><tr><td>" +i+ "</td><tr></table>")
Hi ,
as above code written i am getting overwritten data, ie first row data is overwritten by second row and this way i am getting only second row data in emailContent as i have given in output. need help ! how we can avoid it.
Thank you
Try the following:
var emailContent="<html><body>\
<table>";
emailContent =emailContent+"<tr><td>M_Key</td><td>Powerfactor</td></tr>\
<tr><td>"+rowvalue1+"</td><td>"+rowvalue2+"</td></tr>\"
Note: I did not test the code, please correct syntax if necessary. The idea is to create HTML string in different parts, actually you are creating step by step the content of the email.
Hope it helps,
Raluca Edu
This doesn't work at the moment.
It gives the following error attached in the screenshot.
Hope it helps,
Raluca Edu
