May 20, 2020 11:50 AM UTC
Tab Widget: How to style the white space between tab headers
Is there a way to style the white space between the tab headers using any custom CSS or so? I tried using the below CSS:
.widget-ptcstabset::part(tabs-tab){
     margin-left:0px !important;
     margin-right:0px !important;
But this completely removes the white space. I want that space between tab headers, but is there any way to style or colour it?
Thank you.
cmorfinAnswer
Jun 9, 2020 3:56 PM UTC
Hi @nmt
Just for info there has been an update on the article https://www.ptc.com/en/support/article/CS325847 with a custom css that should allow to configure the colour of the remaining header.
Hope this helps
Christophe
May 21, 2020 11:16 AM UTC
Hi @nmt
CSS has not got many configuration for margin, however there are a few more option for border. So an idea would be to remove the margin and add border:
border-left:24px;
border-right:24px;
border-top:0px;
border-bottom:0px;
border-color:yellow;
border-style:solid;
Hope this helps
Christophe
nmt1-VisitorAuthor
May 21, 2020 12:12 PM UTC
Hi @cmorfin
Thank you for your response!
I tried using the below code and it did remove the space between the tab headers, but the white space after 'Tab Name6' (as in the picture) is still the same, is there a way to style it?
nmt1-VisitorAuthor
Jun 2, 2020 2:19 PM UTC
Hi @cmorfin
I appreciate the efforts you put in and I'll keep a check on that link you provided.
Thank you
