Text to Speech
adiku
11-Garnet
Text to Speech
Is there a way for reading the text and then narrating it by clicking any button in ThingWorx.
Thanks and regards,
Aditya Kumar
adiku
11-Garnet
(To:adiku)
In short, I need to implement text to speech.
Constantine
(To:adiku)
The solution depends on your operating system, but the general approach would be to create a Java extension and either use some Java library for TTS, or execute some command line.
/ Constantine
Vilia (my company) | GitHub | LinkedIn
@Constantine Thanks for the reply. But how to execute the powershell or command line using the service of Thingworx
Constantine
(To:adiku)
For that you'll need to write a Java extension (you'll find plenty of information about it on this website). In this extension you can execute command lines using ProcessBuilder facility, for which you can also find plenty of examples, e.g. here.
/ Constantine
