I provided text field widget with Mask Number. This field is displaying '-' symbol as default. Whenever I typed first digit the symbol '-' replaced with digit. But if the digit value passing from binding, then this widget is displaying '-9' Even though if the passed value is positive it is showing the digit after the symbol -.
As i dont have option to use disable property in numeric entry widget, i have to go ahead with textfield with mask.
Kindly tell me how to overcome this symbol - when numeric value is passed from parameters.
I usually remove the "mask" from the textfield via custom CSS because it just looks... ugly.
.widget-ptcstextfield::part(mask) {
color: transparent;
color: transparent;
