The ComboBox view of List widget can only display the initial value ?
seanccc
Hi ,
I found the  comboBox view of List widget can only display the data for the 1st time ,  the bounded service return different data for the 2nd time then the list display empty.
The dropdown view doesn't has the problem , but it requires panel so is not responsive .
Is it a known issue ?
Thingworx 8.4.2.
Sean
Hello @seanccc,
FWIW it seems to work correctly on 8.5, I've just tried. Do you have an isolated example, which you can share?
/ Constantine
Vilia (my company) | GitHub | LinkedIn
