Hi ,
I found the comboBox view of List widget can only display the data for the 1st time , the bounded service return different data for the 2nd time then the list display empty.
The dropdown view doesn't has the problem , but it requires panel so is not responsive .
Is it a known issue ?
Thingworx 8.4.2.
Sean
Hello @seanccc,
FWIW it seems to work correctly on 8.5, I've just tried. Do you have an isolated example, which you can share?
/ Constantine
