The Relationship Subsystem must be enabled
IB_9961693
11-Garnet
I get following error when I want to search for a referenced service :
"The Relationship Subsystem must be enabled, configured, and running to view references. You can manage this from the RelationshipSubsystem.".
When I go to the "Subsystem:RelationshipSubsystem" it's already enabled because for other entities(things) it works.
Any idea what can be the problem ?
Izzet
5 REPLIES 5
Hi @VladimirN ,
the referenced by feature is already enabled, because for other services the reference is working but for this 1 service not. Still gives the message to enable it when clicked on reference by.
Hi @IB_9961693 ,
1. How exactly are you searching for a service reference by clicking on "Reference by"?
That tab is available only at the Thing level, and lists all the references for that Thing, regardless of characteristics (eg: it does include services at this level).
Maybe you're referring to a Thing and by mistake you mentioned "service" ?
2. Disable, Save, then Enable and Save back the Relationship subsystem. If this issue manifests again, please open a Support Ticket.
Hi, @VladimirRosu ,
I'm indeed referring to a Thing (my mistake).
Did as you said, disable-save-enable-save and also a restarted th  Thingworx server. Did not help.
I'll see what I do next.
Izzet
Hi @IB_9961693
The next thing to do here is to raise a Technical Support ticket.
Please let us know what was the result of that, for the benefit of others browsing this forum.
Thanks!
