The Thingworx system filters garbage data, There is no good plan?
lliangjb
Hello, everyone.
     We collect a lot of useless data when we get data from the device side,Is there a good way to filter out the garbage data?
     I'm using data collected from the Java SDK!
liliu
8-Gravel
(To:lliangjb)
Hi Mr. Guo,
Using QueryPropertyHistory will return duplicate records. It's doesn't means we logged it.
As I know, the values stream doing regords, would follow DataChange Type in the property settings.
Best Regards,
Lily
ankigupta
(To:lliangjb)
Hi Ju Bin Liang​,
Can you please share your use case in more detail.
In Java SDK you can update code to send only requisite data.
In ThingWorx; you can add query in your Service to retrieve the filtered data.
liliu
8-Gravel
(To:lliangjb)
Hi Mr. Guo,
May I know what kind of garbage data do you received? (Value stream? DataTable?)
Best Regards,
Lily
lliangjb
(To:liliu)
hi,Lily
     I want to filter the data before it goes to thingworx
liliu
8-Gravel
(To:lliangjb)
Hi Mr. Guo,
Best Regards,
Lily
