I have JAVA 11 installed, and postgres 13.9 installed with all the paths correctly indicated in the system.
I have created a self signed certificate for an SSL installation
I am trying to install ThingWorx on the
However there is nothing in the directory, and there is not a log file.
Ideas?
the log file from the installer is located in the user\AppData\local\Temp\bitrock_installer<date>.log directory
See the article: Article - CS322165 - How to enable and collect Installer debug logging for ThingWorx Platform, ThingWorx Flow and ThingWorx Navigate
You may also need to collect the logs before closing the dialog box which pops up. When you close this box the installer may be cleaning up the log file.
HTH
Peter
HTH
Peter
Thank you,
Took me a bit, yet discovered that the user\AppData folder is hidden, and the show hidden folders and files "button" had moved locations since the last time I used it.
I captured the log files, and shared them with PTC Support. I am awaiting their feedback.
Preston
