ThingWorx-Analytics: Creation of predictive model failed
DF_10027356
6-Contributor
Hello all,
I want to create a predictive model with an ordinal goal variable based on a time series dataset of around one million entries. Unfortunatly the creation always failed with the error you can find in the attachment. Does anybody know how I can fix this problem?
Here are some more information:
- ThingWOrx Version: ThingWorx 9.0.2
- Used learners in the model: Neural_Net, Decision_Tree and Gradient_Boost
- Used Ensambler: Average
- LookbackSize: 4
- No use of goal history
Thank you already in adcance.
Kind regards
David
cmorfin
(To:DF_10027356)
Hi David
From the screenshot you posted, the issue is due to an OutOfMemory error. This happens when working on large dataset.
Try the steps from https://www.ptc.com/en/support/article/CS294545 to increase the memory allocated to the workers
Christophe
DF_10027356
6-Contributor
(To:cmorfin)
Hi Christoph,
unfortunately I still get the same error after following the steps from the link you posted. Do you have any other idea how I can solve my issue?
Thank you for your support.
Best regards
David
cmorfin
(To:DF_10027356)
Hi @DF_10027356
Could you then download the TWALogCollector , execute it on the ThingWorx Analytics machine and post the resulting zip or gz file here ?
Thank you
Christophe
