ThingWorx Analytics: Signals for Ordinal Data
DF_10027356
6-Contributor
Hello all,
I am working with ThingWorx Analytics 9.0 and I want to perform a Signals analysis. My dataset is a time-series dataset and my goal variable is from type ordinal. My question: Is there a possibility that I can perfrom a signals job with this dataset?
Thank you already in advance.
Kind regards
David Falkenstein
cmorfin
(To:DF_10027356)
Hi David
You should be able to generate a signal for Ordinal goal, however this features is not supported in Analytics Builder for now.
Therefore you need to use the CreateJob() service of the AnalysticsServer_SignalThing
Then use the  AnalysticsServer_SignalThing.RetrieveResults() with the jobid returned by CreateJob()
Hope this helps
Christophe
cmorfin
(To:DF_10027356)
Hi David
Hope this helps
Christophe
DF_10027356
6-Contributor
(To:cmorfin)
Hi Christophe,
thank you very much this helps a lot. I have just one more question: which job tags do I have to add to the signals so that I can see them in the analytics builder (I just want to see them there, no further editing). I know that something like this can be done with created models with the service "AddJobTags". Is something similar possible with signals? And if so which job tags do I have to add?
Thank you for your support.
Kind regards
David
cmorfin
(To:DF_10027356)
Hi David
It is not possible here. Adding the tags does break Builder because it does not understand this type of signals
Christophe
DF_10027356
6-Contributor
(To:cmorfin)
All right.
Thank you for the quick support.
