ThingWorx Entities like Mashups Storing
VijayBhimraoCha
    Where are the ThingWorx Entities like mashups are stored/Saved? Can that be saved in different folder structure?
The usecase is, need to have same name mashup at different folders like can have same name document in different folders. And then should be able to  invoke through REST like Thingworx/Mashups/Planning/MyOpenWork   and Thingworx/Mashups/Change Management/MyOpenWork
How can this be made possible? Any pointers, links to relevant documentation will help here.
Thx.
Vijay
You can't control TW on that way, don't expect to use REST URLs on your own desires.
VijayBhimraoCha
(To:CarlesColl)
Is there any way to achieve similar behaviour/functionality?
If you want to keep track of the Mashups you are managing you could always use custom tags to make searching for them in Composer easier.
Vijay, Unfortunately you are not going to be able to control where Mashups are stored. All Mashups are accessible via the REST API like so: "localhost/Thingworx/Mashups/MASHUP_NAME" You need to modify the IP address, port, and protocol as necessary to fit your server configuration.
