ThingWorx: Failed to load a Oracle workflow connection
LeonWilson_21
7-Bedrock
I am trying to build a standard workflow using the SQL Connector/Execute Stored Procedure action using Oracle. This approach is to pull data to a mashup. The issue is that while trying to enter the configuration to setup the account/connection it fails to add the connection, The account is active and working.
Hi @LeonWilson_21.
What version of ThingWorx are you running?  Are you setting up the workflow in ThingWorx Flow?  If so, what version of Flow are you running?  What error are you getting?  It's possible you're missing a driver or Oracle libraries needed for connecting.
--Sharon
