Hello @SS_10396212 ,
Pls share if you have a question. The subject field in this post is empty.
Regards
Bhawna
How to add Subject? I am not able to add. Please help
Hello @SS_10396212
You can post your query in response field here. However, form the next time onwards, you can post your query in the description box.
Bhawna
Thanks.
As a note for anyone reading this post in the future, the only place where the GitHub extension is hosted (source code and releases) is https://github.com/PTCInc/thingworx-gitbackup-extension.
If anyone has any issues with it the first step is to read the User Manual included in each release, then if the problem was not solved, to raise an issue here
