Feb 20, 2017 9:55 PM UTC
ThingWorx Grid Widget Questions
Hey all,
I have some questions regarding the Grid Widget in ThingWorx :
- Is there a way, in a Grid Widget, to adjust the text based on the cell Size. So if the text is too big to be contained in the cell, it'll make another line and keep the cell resolution ?
- Is there a way to, without creating a new Widget, to have in a single cell, a text and a clickable image ?
- Is there a way to remove the ability to scroll from the mouse and from the scrolling bar ?
posipovaAnswer
20-Turquoise
Feb 21, 2017 5:04 PM UTC
Update:  I've just tested with the html field datashape, and it seems to work as expected:
20-Turquoise
Feb 21, 2017 1:09 AM UTC
Hi, to answer all of your questions shortly, such functionalities are currently not available.
I will submit an enhancement request on your behalf during the US business hours and update this thread with the ticket numbers. Please keep in mind that the delivery of enhancement requests is not guaranteed and being prioritized according to the demand and the availability/workload of the R&D team. You may look into a custom extensibility, and developing a custom widget - let me know if you would like me to provide/point you to the documentation.
fgrondin1-VisitorAuthor
Feb 21, 2017 4:32 PM UTC
Thank you.
It would be great if you can provide me the documentation to create a custom extensibility.
Do you think for my second question, it would be possible to have in the datashape a HTML type field in which I could set a <p> and a <img> ?
Thank again,
Frederik Grondin
20-Turquoise
Feb 21, 2017 4:38 PM UTC
You may try the html idea as a potential workaround - I'm not entirely sure if the tags will all keep their proper function. Also, please note I've sent you a direct message.
For the extensibility, please see attached.
Feb 21, 2017 8:06 AM UTC
Hi Frederik,
If I understand well your first question, yes it's, use CellWrap to true and set column size to a fixed size.
For the second and third you are out of luck as Polina said.
Carles.
Feb 21, 2017 4:22 PM UTC
Thank you for the suggestion.
As for me, it does't work.
