The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hello All,
In previous releases of Navigate you could click on the grid widget and apply state definitions to the grid directly. IN the latest release of Thingworx Navigate they use Grid Advanced and Tree Grid Advanced widgets that do no allow you to apply the state definitions directly. Is there a a workaround for this? I am trying to have the background color of each cell of the State column be dependent on the value of the state returned. (Example: Released = Green, In Work = Red, etc.)
Can you specify which version of Navigate and Thingworx are you working on?
Bibek
Hi Bibek,
I'm running Thingworx 8.1 and Thingworx Navigate PLM Extension 1.6
