ThingWorx Installation on Localhost
nbojanala
I am trying to install thingworx on my local host.
when i try to deploy the war file session is getting timed out and when i refresh the webpage i can see the war file is deployed
with Running Status  - False , Below is the error message when i start thingworx application in tomcat manager.
Fail - Application at context path /Thingworx could not be started
Note : i did follow the steps provided in the document(http://support.ptc.com/WCMS/files/169063/en/Insta...)
ThingWorx version - Thingworx-Platform-6.0.8-b35
Attached is the catalina log file.
Nihanth
Aanjan
(To:nbojanala)
Nihanth, if there is a stderr file, please post that too.
On a side note, from the logs, I see that you are using Tomcat 7. ThingWorx 6.x versions require Tomcat 8 and Java 8. Please do retry with those instead.
2 REPLIES 2
Aanjan
(To:nbojanala)
Thanks Ravi, It works now
