ThingWorx Trial Edition - Analytics Server Things missing
NiklasF
8-Gravel
i installed ThingWorx Anlaytics Trial version.
Unfortunately it does not run properly because i  am not able to see  the AnalyticsThings or can do the AnalyticsServer Configuration.  Please see my screenshots and log files of  the installation.
Thanks for your help!
mgoel
(To:NiklasF)
@NiklasF
Thank you so much for confirmation. Request you to open a new thread for new query. Please mark accept as solution for this thread so that we can close this thread.
Thanks in Advance.
Regards- Mohit
11 REPLIES 11
Screenshots attached
mgoel
(To:NiklasF)
@NiklasF
Could you please check in services tab if all the services are running or not?
Mohit
NiklasF
8-Gravel
(To:mgoel)
@mgoel
Thanks for your reply.
Which service tab do you mean? Where can i find it?
mgoel
(To:NiklasF)
@NiklasF
Are you using Windows? I have attached a screenshot for window services. Please check!
NiklasF
8-Gravel
(To:mgoel)
@mgoel
Yes i am using Windows.
I checked my services and i can not see any service related to ThingWorx ...
I am currently running the composer  over  "anaylitcs trial start" succesfully .
mgoel
(To:NiklasF)
@NiklasF
Could you please have a look at this article.
https://www.ptc.com/en/support/article?n=CS271012&posno=1&q=can%20see%20analytics%20things&source=search
Do let me know in case of any question.
Regards- Mohit
NiklasF
8-Gravel
(To:mgoel)
@mgoel
Hello!
I checked the Article - CS271012 (https://www.ptc.com/en/support/article?n=CS271012)
Where can i find those  log files:
  • <ThingWorxAnalyticsServer>/data/logs/edge-ms.log (Windows) reports
  • Datams.log reports
In my   ThingWorxAnalyticsServer folder i do not have a "data" folder.
My application key is valid and correct. I created also a new one with admin user and changed it in the  config files. No  improvement.
Article CS271819 (https://www.ptc.com/en/support/article?n=CS271819):
Can you tell me also where i can find those log files?
Can you please  check the attached  logs from my ThingWorx Monitor
Thank you very much!
NiklasF
8-Gravel
(To:mgoel)
@mgoel
Hello!
mgoel
(To:NiklasF)
@NiklasF
Can you please send your Analytics logs inside Analytics server folder.
NiklasF
8-Gravel
(To:mgoel)
@mgoel
Please find my  Analytics Logs attached.
I have some progress here. Our internal firewall blocked the docker ip adress. Now i ´am able to see the Analytics Things in ThingWorx !
Now i wanted to do this learning:
https://developer.thingworx.com/resources/guides/analytics-builder-quickstart/signals-and-profiles
And here i am heading  the  next problem. Every time i set up my data model   and configure my "Signal" in   AnalyticsBuilder    i´m loosing connection in the AnalyticsBuilder  and the attached "Status Message" appears showing:
"Could not load "TW _ML_Landing_Page_v1". Reason: 0 -
"Could not load "TW_ML_Signals_Horizontal_v1". Reason: 0 -
"Could not load "TW_ML_Profiles_Horizontal_v1". Reason: 0 -
One strange thing is that  when i upload the vibration data  it   says "...progress " but never finish  but If i click cancel  after some time my data is  uploaded
Thank you!
But the
mgoel
(To:NiklasF)
@NiklasF
Thanks in Advance.
Regards- Mohit
