ThingWorx content loader SSL error
czjakubo
I am trying to call a REST API, which is using https and certificate issued by Lets Encrypt, using Resources["ContentLoaderFunctions"].GetText
Unfortunately I am getting this error:
PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target.
If I select the option ignoreSSLErrors: 1, then I get this error:
Certificate for hostname doesn't match any of the subject alternative names
I tried to import the server's certificate to Java certstore, but it didn't help. I am running ThingWorx 9 as Docker container. What do you think can be the problem?
Thank you for your help
CS_9203536
6-Contributor
(To:czjakubo)
Did you solve the issue? I ran into the same problem, also with a Docker instance.
czjakubo
(To:CS_9203536)
Hi, unfortunately I didn't
