I'm installing ThingWorx8.4 on Postgresql, but got error "Improper value found for model provider configuration password, system cannot start without valid password" when launch tomcat. I've executed
thingworxPostgresDBSetup.bat and thingworxPostgresSchemaSetup.bat without errors , so I'm sure that the password in the platform-settings.json is correct for the postgresql user "twadmin".
If switch to H2 database , then tomcat can launch successfully and Thingworx application works well.
Any suggestions ? The tomcat error log and platform-settings for H2 and PostgreSQL are attached.
==================Environment Information===============
ThingWorx version: 8.4
OS: Windows server 2012 R2
Tomcat: 9.0
Database: PostgreSql 10
JDK: Oracle 1.8.0_192/64bit
Can you try with just this in platform-settings for postgres?
"PlatformSettingsConfig": {
"AdministratorUserSettings": {
"InitialPassword": "Adminxxxxxx"
"LicensingConnectionSettings": {
"username": "******",
"password": "******",
"timeout":"60"
"PersistenceProviderPackageConfigs": {
"PostgresPersistenceProviderPackage": {
"ConnectionInformation": {
"jdbcUrl": "jdbc:postgresql://localhost:5432/thingworx",
"password": "Adminxxxxxx",
"username": "twadmin"
"timeout":"60"
