Thingpredictor - Failed to deploy model
laue
Currently, i am using Thingpredictor as Analysis Provider.
Unfortunatly, I'm not able to publish any Analytics(8.2) Model in Analytics Builder. Instead, I get the following Message: "Model deployment failed on connector Exhausted the specified waiting time for model deploy, aborting... : <modelname>"
In the command prompt of ThingPredictor I get the this Message:
INFO  [2018-06-22 02:25:56,833] com.thingworx.communications.client.things.filetransfer.FileTransfer
VirtualThing: Starting file transfer. tid: 0db5b07e-72df-4352-bda7-f5a1ad8860f2, path: TempModelDir/
bosch_0-062ml_120grad_bearb2_Peroxid_1e5a2425-9ecc-466a-85a3-36c3e4d42296.xml, mode: write
INFO  [2018-06-22 02:25:56,848] com.thingworx.communications.client.things.filetransfer.FileTransfer
VirtualThing: Completed file transfer. tid: , message: Transfer complete
WARN  [2018-06-22 02:25:56,848] com.ptc.analysis.client.impl.AnalysisClient: checksums don't match ,
 overwriting file
ERROR [2018-06-22 02:25:56,864] com.thingworx.analysis.TWAnalysisAgentAdapter: Failed to deploy mode
l [bosch_0-062ml_120grad_bearb2_Peroxid_1e5a2425-9ecc-466a-85a3-36c3e4d42296]
! java.lang.ClassNotFoundException: com.sun.xml.internal.bind.v2.ContextFactory
! at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(Unknown Source)
! at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(Unknown Source)
! at java.base/java.lang.ClassLoader.loadClass(Unknown Source)
! at javax.xml.bind.ContextFinder.safeLoadClass(ContextFinder.java:532)
! at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:205)
! ... 12 common frames omitted
! Causing: javax.xml.bind.JAXBException: null
! at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:207)
! at javax.xml.bind.ContextFinder.find(ContextFinder.java:414)
! at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:618)
! at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:565)
! at org.jpmml.model.JAXBUtil.getContext(JAXBUtil.java:125)
! at org.jpmml.model.JAXBUtil.createUnmarshaller(JAXBUtil.java:163)
! at org.jpmml.model.JAXBUtil.unmarshal(JAXBUtil.java:75)
! at org.jpmml.model.JAXBUtil.unmarshalPMML(JAXBUtil.java:63)
! at com.thingworx.analytics.ccc.pmml.PmmlUtils.readStream(PmmlUtils.java:342)
! ... 4 common frames omitted
! Causing: java.lang.RuntimeException: Couldnt read PMML from stream
! at com.thingworx.analytics.ccc.pmml.PmmlUtils.readStream(PmmlUtils.java:344)
! at com.thingworx.analysis.TWAnalysisAgentAdapter.DeployModel(TWAnalysisAgentAdapter.java:170)
! at com.ptc.analysis.client.impl.AnalysisClient.processModel(AnalysisClient.java:475)
! at com.ptc.analysis.client.impl.ModelDownloadManager.lambda$modelUpdated$0(ModelDownloadManager.ja
va:88)
! at java.base/java.lang.Thread.run(Unknown Source)
ERROR [2018-06-22 02:25:56,864] com.ptc.analysis.client.impl.AnalysisClient: Failed to deploy file o
n analysis service ,removing file
ERROR [2018-06-22 02:25:56,864] com.ptc.analysis.client.impl.ModelDownloadManager: Failed to process
 model Model: bosch_0-062ml_120grad_bearb2_Peroxid_1e5a2425-9ecc-466a-85a3-36c3e4d42296,URL : null ,
 FileName C:\Users\laue\Desktop\ThingWorx-Analytics-ThingPredictor\.\AgentWorkDir\TW.AnalysisService
s.ThingPredictorConnector\Models\bosch_0-062ml_120grad_bearb2_Peroxid_1e5a2425-9ecc-466a-85a3-36c3e4
d42296.xml
! com.thingworx.common.exceptions.InvalidRequestException: File Does Not Exist
! at com.thingworx.communications.client.things.filetransfer.FileTransferVirtualThing.checkFileExist
s(FileTransferVirtualThing.java:707)
! at com.thingworx.communications.client.things.filetransfer.FileTransferVirtualThing.DeleteFile(Fil
eTransferVirtualThing.java:607)
! at com.ptc.analysis.client.impl.AnalysisClient.processModel(AnalysisClient.java:483)
va:88)
I have no idea to fix this.
laue
zyuan1
18-Opal
(To:laue)
Hi Laue,
Please answer to my following questions:
1. Is this your first time to publish the model, have you finished configuration in Analytics Manager page?
2. Is the dataset & model you're publishing coming from a sample data or a customized dataset
3. What's your TWX, TWA server and TWA extension version?
cmorfin
(To:laue)
Hi
Also make sure you are using a Java 8 not a Java 9 or 10.
See https://www.ptc.com/en/support/article?n=CS277708 - same error as you are getting.
Kind regards
Christophe
