The following error cause a lot of problems about widget runtime:
Hello Gabriele,
Which extensions need to be modified is dependent on what you currently have installed on your ThingWorx Platform. All affected extensions needs to be modified in order to work on 8.5.0. This is the case until the release of ThingWorx 8.5.1 which is expected at the end of this month. 8.5.1 has modified this requirement so a manual update to the affected extensions is no longer required.
If you are unable to wait for or upgrade to 8.5.1 I would recommend you open a case with PTC Technical Support via the PTC Support Portal. If you would prefer you can send me your Customer Number and SCN via Private Message and I can open the case for you.
