Thingworx 9.1.1 Release
bot1q
Does this mean we cannot navigate inside our solutions? Not even open a popup?
4 REPLIES 4
slangley
23-Emerald II
(To:bot1q)
Hi @bot1q.
The section you indicated is referring to the Navigation function found in the lower right corner of your workspace.  Here is a link to the Navigation function in the Help Center.
--Sharon
bot1q
(To:slangley)
Thanks, but i am really good familar with Thingworx.
My question is: The navigation is broken in 9.1.1, so that we can't even call a PopUp or navigate threw the Application?
slangley
23-Emerald II
(To:slangley)
Hi @bot1q.
The navigation function will still work, but there are some issues passing in mashup parameters.  Are you running into a specific problem?  If so, please provide the details so we can investigate.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @bot1q.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
