Does the ThingWorx 9.6 installer support Azure SQL as a database? I know that manual installation supports it.
Thank you!
Hi @AK_10385731 No, the ThingWorx 9.6 installer does not support Azure SQL as a database.
Thank you @Surya_Tiwari for your swift response.
Just to verify, does manual installation support Azure SQL right?
