I signed up for the hosted server trial - have about 27 days to go. I'm able to connect through the REST API and postman to my server, however Thingworx Academic Simulator doesn't seem to connect - I get the messages(after a 10 second timeout) - 'Unable to connect, check your port' - looked at the code for Thingworx Academic Simulator (which is an electron/node.js app) and it seems that the interface is just sending a REST API call to /Thingworx/Things before issuing that message (which seems to be the default one). Can't understand why the TAS isn't working when the REST API does in Postman with 200 OK. Any idea what's going on? Have checked my firewall etc and nothing is blocking.
My settings:
Server URL: pp-2010211547rh.devportal.ptc.io
Application Key (used a member with privileges on things as well as administrator)
Port: 8443 (or 443 - both work with REST API)
Secured Server checked on
Based on your description, actually you have already checked many points.
What's your thingworx version? As I know
Maybe you already tried below but provide them for your reference:
In addition, I noticed a similar issue similar with yours:
Best Wishes!
Teresa
Best Wishes!
Teresa
Hi @Assembly.
If the previous response helped you to find a solution, please mark it as the Accepted Solution for the benefit of others with the same issue.
Regards.
--Sharon
