Thingworx Alert stream customization
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
We have a requirement where we need to have an option to acknowledge each alert from same property.
In inbuilt alert system, its acknowledge at Thing level/property level is what I understand.
Any option for customizing the stream / adding a column for acknowledgement?
We also wanted to know the property value at the time of alert generation .(if alert condition is set to value>5 ,in case I get a value=10, while fetching alert history ;as per inbuilt alert system I don't get the actual value as part of alert data) .
I have got close to 20k properties updating every 15 sec. And 80% of them have alert conditions.
Would custom stream creation for customization alert information cause issue on performance?
- Labels:
Design
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
They have the Message field to show user what problem trigger the alert in Alert Summary.
Monitoring- Alert Summary - Message
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thanks for you response Zyuan
For integer or number value, seems like actual value at that time is being displayed as message.
But for string type alerts ,message not equal to "configured value" and not the actual value at that time.
Also ,do you have any solution for acknowledging individual alarm events of same property ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I was checking if we could change default data shape of alerts in order to check if I can add a column for acknowledgement, so that against each event of alert, I can update a acknowledgement statement.
As of now, I assume acknowledgment is a new row entry in the same stream.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
If it's just for String property, How about creating a new Stream and use subscription to log it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Ok, so you suggest having subscription on alert event and have all the info logged in a new stream and may be periodically delete the already existing alert stream ? or having a subscription on value change event to identify alerts and log into another stream.
