Thingworx Analytics 8.1 API Example
jrajesh
I am trying to explore the Thingworx Analytics API - 8.1. I was trying to use the GetDatasetSchema service on the localhost-AnalyticsServer_DataThing as a REST API. Although there is API guide at ThingWorx Analytics API , an example will help me.
Any documents giving example usages for the TWX Analytics API 8.1?
Thanks and Regards,
Jyothi
cmorfin
(To:jrajesh)
Hi Jyothi
You may want to have a look at this article: https://www.ptc.com/en/support/article?n=CS271485
There are some explanation and most importantly, as far as example as concerned, you have a json collection file (at the very bottom) that you can download and import into, let's say Postman, to check some examples.
Hope this helps.
Kind regards
Christophe
7 REPLIES 7
cmorfin
(To:jrajesh)
Hi Jyothi
Hope this helps.
Kind regards
Christophe
jrajesh
(To:jrajesh)
Hi Christophe,
Thanks you very much for getting back... that really helped!
I am particularly trying to use the API
http://127.0.0.1:8888/ThingWorx/Things/localhost-AnalyticsServer_DataThing/Services/GetDatasetSchema
The documentation at ThingWorx Analytics API mentions the details. I am giving the body as follows, But I am still getting a 404. Any ideas what might be going wrong?
{"dataSource": {
                "dataShape": {
                    "fieldDefinitions": {
                        "datasetUri": {
                            "name": "datasetUri",
                            "description": "Location of the data",
                            "baseType": "STRING",
                            "ordinal": 0,
                            "aspects": {}
                        "format": {
                            "name": "format",
                            "description": "Structure of the data (CSV,PARQUET,CLQUET)",
                            "ordinal": 0,
                            "aspects": {}
                        "filter": {
                            "name": "filter",
                            "description": "SQL WHERE clause to refine the dataset",
                            "ordinal": 0,
                            "aspects": {}
                        "exclusions": {
                            "name": "exclusions",
                            "description": "Fields to remove from the dataset",
                            "baseType": "INFOTABLE",
                            "ordinal": 0,
                            "aspects": {
                                "dataShape": "GenericStringList"
                        "data": {
                            "name": "data",
                            "description": "An infotable of data (must be flat. for providing data as part of request)",
                            "ordinal": 0,
                            "aspects": {}
                        "metadata": {
                            "name": "metadata",
                            "description": "Metadata of the dataset (for providing data as part of request)",
                            "ordinal": 0,
                            "aspects": {
                                "dataShape": "AnalyticsDatasetMetadata"
                "rows": [
                        "datasetUri": "dataset:/1715c6d4-a513-44fa-be49-68fcd1075642",
                         "format": "parquet"
Thanks and Regards,
Jyothi
cmorfin
(To:jrajesh)
Hi Jyothi
I have used your code and it works for me.
Since you are gettign a 404 error this woudl indicate that the URI has some error.
Are you sure of the Thing name in the URI ?
Christophe
jrajesh
(To:cmorfin)
Hi Christophe,
The Thing name is correct. I could execute the ListCreatedDatasets API with this thing. Is there a way to access the http access logs to understand what is the REST URI that reached the server? I can compare mine with the one executed via Thingworx Test Services. The same service executed via ThingWorx works fine.
Thanks and Regards,
Jyothi
cmorfin
(To:jrajesh)
Hi Jyothi
You can get the access.log (and error.log) with the command: docker cp nginx:/var/log/nginx .
This will copy the /var/log/nginx folder to the local path, change . with the full path to the local directory if you want it somewhere else.
hope this helps.
Kind regards
Christophe
jrajesh
(To:jrajesh)
I am now trying to create a Javascript service in my own ThingTemplate which internally calls the GetDataSchema. This is how I am doing it.
var dataSet = Things['localhost-AnalyticsServer_DataThing'].ListCreatedDatasets();
var params = {
infoTableName : "InfoTable",
dataShapeName : "AnalyticsDatasetRef"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(AnalyticsDatasetRef)
var infoTable1 = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
// AnalyticsDatasetRef entry object
var newEntry = new Object();
newEntry.filter = dataSet.filter; // STRING
newEntry.datasetUri = dataSet.datasetUri; // STRING
newEntry.metadata = dataSet.metadata; // INFOTABLE
newEntry.data = dataSet.data; // INFOTABLE
newEntry.format = dataSet.format; // STRING
newEntry.exclusions = dataSet.exclusions; // INFOTABLE
infoTable1.AddRow(newEntry);
logger.debug(infoTable1);
result = Things['localhost-AnalyticsServer_DataThing'].GetDatasetSchema(infoTable1);
But I am getting the error:
Wrapped java.lang.Exception: Invalid parameter type for service : [GetDatasetSchema] on localhost-AnalyticsServer_DataThing Cause: Invalid parameter type for service : [GetDatasetSchema] on localhost-AnalyticsServer_DataThing
Any ideas?
Thanks and Regards,
Jyothi
jrajesh
(To:jrajesh)
Got it!
var params = {
dataSource: infoTable1 /* INFOTABLE */
// result: INFOTABLE dataShape: AnalyticsDatasetMetadata
result = Things["localhost-AnalyticsServer_DataThing"].GetDatasetSchema(params);
