Thingworx Analytics Extension - Import Error
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hello everyone,
When I try to import ThingWorx-Analytics-8.1.0, I got two error;
- Unable to process import: Unable to update mediaEntity: ModelTagVocabulary [TW] Already Exists
- Unable to delete ThingWorx_Analytics_Console_Extension:8.1.0. This is likely due to other errors: ExtensionPackage ThingWorx_Analytics_Console_Extension Does Not Exist
I checked the entity which name is Applications. Also, Model Tags->Applications->Manage Terms is empty. I don't know what is the reason. Could somebody help me?
- Labels:
Analytics
Extensions
Install-Upgrade
- Tags:
- thingworx analytics
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Ozkan
I think I have isolated the root cause. I was able to reproduce the same behaviour as you had.
It appears that the root error is not " Unable to update mediaEntity: ModelTagVocabulary [TW] Already Exists" . This is an error you got after a subsequent import attempt.
Upon first import the error was "Unable to process import: License is not available for Product: THINGWORX_FOUNDATION Feature: twx_named_user"
You indeed do need to have a twx_named_user feature in order to import the ThingWorx Analytics Extension.
You would therefore need to check on the Licensing tool the activation ids that you have got for the Product ThingWorx - User and add it to your device.
Then you should be able to import the extension.
As mentionned above I did indeed got the same situation without twx_named_user, but was able to import after adding it.
Kind regards
Christophe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Ozkan
Could you please attach your ApplicationLog.log file ?
Also could you confirm:
- what is yoru persistence provider- is it a fresh installation of ThignWorx 8.1 or an upgraded one ?
- did you have a previous extension of ThingWorx analytics already installed
- did you attempt several time to install the extension
- what is the OS on which you run ?
Thank you
Kind rgeards
Christophe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Christophe,
Firstly, thanks for your reply.
I attached log file, also you can find my answers below. Thanks again.
- Not upgrade, I installed new on new vm.
- Nope, I never try to install previous version of extension. I deployed new tw instance after that I tried to import analytic extension.
- Yes,
- Windows Server 2016
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Ozkan
In Composer could you access Model Tags (under MODELLING), do you see a TW model tag here ?
Could you also post the extensions listed under Import/Export > manage ?
Thank you
kind regards
Chrisotphe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Chrisotphe,
Model Tags has just Application entity. Extension list is empty. I checked it from menu (Import/Export > Manage)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Ozkan
Kind regards
Christophe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Christophe,
Thank you so much. I found the correct key.
