Thingworx Analytics Server
jzhao1
Hi,friends!
I can't download packer-post-processor-vhd-0.3.0-windows_amd64.exe. Who can send it to my email?
Thank you !
cmorfin
(To:jzhao1)
Hi Juanjuan
the packer is only needed when installing ThingWorx Analytics Server 7.4 or earlier.
Do you have a requriement to install this version ?
Is it not possible for you to use the latest release 8.0 .
Release 8.0 uses a different installation process that does not need packer, see Video Link : 1902
Hope this helps
Kind regards
Christophe
Hi Christophe, the client is not using ThingWorx 8.x, so she decides to use TWA 7.4 server to avoid version problem. I've send her the .exe file already.,
jzhao1
(To:zyuan1)
Thank you!
jzhao1
(To:cmorfin)
The problem has already been solved.Thank you!
