Thingworx-Bigquery connection
jgp
8-Gravel
8-Gravel
Hi, Is there any way to send data from Thingworx to Bigquery database?
8 REPLIES 8
Hi @jgp   We do support connections via jdbc to third-party databases.  You'll need to follow these instructions:
  1. Download the JDBC driver from BigQuery
  2. Copy the driver to <tomcat_home>\lib
  3. Restart Tomcat
  4. In Composer, create a Database thing
  5. In the Configuration tab for the Database thing, enter the details for connecting to your database
Surya
Many thanks @Surya_Tiwari , for your fast reply.
But, is it the only way to connect with Bigquery Database?
Best regards
Hi @jgp  Look at the reference article for this.
Rocko
18-Opal
(To:jgp)
Bigquery has a REST API as well that you could call from ThingWorx using the ContentLoader.
jgp
8-Gravel
8-Gravel
(To:Rocko)
Many thanks @Rocko for your suggestion. Is it possible to have an example?
Thanks for advance.
Rocko
18-Opal
(To:jgp)
I'd leave that as your homework
It would go roughly like this:
let params = {
    url: "https://bigquery.googleapis.com/bigquery/v2/projects/PROJECT_ID/datasets/DATASET_ID/tables", // Replace with your BigQuery API endpoint
    headers: {
        Authorization: "Bearer YOUR_ACCESS_TOKEN", // Replace with your access token
        Accept: "application/json"
 result = Resources["ContentLoaderFunctions"].GetJSON(params);
You can read about ContentLoader here:
https://community.ptc.com/t5/IoT-Tips/ContentLoaderFunctions-in-ThingWorx/ta-p/820230
https://community.ptc.com/t5/ThingWorx-Developers/Consume-REST-API-services-in-Thingworx/td-p/525630
jgp
8-Gravel
8-Gravel
(To:Rocko)
Thanks @Rocko for your help.
This example is to read from Bigquery, right? What should I do to send data to Bigquery instead of reading it? This would be the main function.
Best regards
Rocko
18-Opal
(To:jgp)
You would use the PostJSON service instead. For BigQuery API you will need to find out at the BigQuery help pages.
