Thingworx Eclipse Plugin
nahuel
Hi community,
According to April's post this year the Thingworx Eclipse Plugin should be located here.
But I'm not being able to find it.
Where can I find the Thingworx Eclipse Plugin?
Nahuel
slangley
(To:slangley)
Hi @nahuel.
The decision was made to return several extensions to the PTC Support Downloads page.  You should be able to locate the Eclipse Plugin extension there now.
Once you download the extension, I recommend storing it for later retrieval in your environment as plans are to permanently remove it once it has been posted on github.
--Sharon
slangley
(To:nahuel)
Hi @nahuel.
I have reached out internally on this and will provide more information once I receive a response.
--Sharon
slangley
(To:nahuel)
Hi @nahuel.
A decision was made recently to end support on several extensions.  Please refer to this community post for more information.
That being said, if you were already using this extension, you can submit a justification and I will open a case and internal ticket for submitting the request.  There will be an approvals process, so I can't guarantee that the extension will be provided, however.
If you would like to submit the justification and don't feel comfortable making it public, please feel free to submit it via private message.
--Sharon
slangley
(To:slangley)
Hi @nahuel.
--Sharon
nahuel
(To:slangley)
Thank you @slangley. I'll be downloading them.
Nahuel
slangley
(To:nahuel)
Hi @nahuel
If you feel your issue has been resolved, please mark the appropriate response as the Accepted Solution for the benefit of others with the same issue.
--Sharon
