My thingworx server crashs here is my hostname :
PP-1805230841UO.devportal.ptc.io
Thank you.
Hi @Alexis00.
Please make sure your server is running. It is designed to shut down after a couple of hours of non-use. If you still have an issue, post a reply and we will track down the appropriate team.
Regards.
--Sharon
Hi @Alexis00.
Regards.
--Sharon
I have the same issue another time.
Hi Alexis,
I've gone ahead and restarted your Eval server. You should be able to access it now. Let me know if have any issues.
Thanks - Paul
