We are working to address an issue with subscription email notifications. In the meantime, be sure to check your favorite boards for new topics.
Am unable to load the URL for Thingworx Flow. Is this the right URL? How can I navigate to Thingworx Flow Editor to start the development.
Installation was successful but this page is not showing any content and is empty without any error messages. Also, I have checked the port number from nginx configuration file.
Can anyone please help?
Port for Flow is not 8080, please access Flow with this link:
https://<hostname>/Thingworx/Composer/apps/flow
<hostname> is the same as server_name in vhost-flow.conf file located at C:\Program Files\nginx-1.13.12\conf\conf.d
Thank you,
Raluca Edu
Thank you,
Raluca Edu
Thank you raluca_edu
Small correction to your suggestion:
https://<hostname>:<port>/Thingworx/Composer/apps/flow/
Above URL worked. But have to use the actual host name (but not localhost) and port available on C:\Program Files\nginx-1.13.12\conf\conf.d
