Thingworx HA mode Apache Ignite log4j vulnerability
RosJir
2-Guest
I have a question regarding compatibility of Apache Ignite client used by Thingworx platform for enabling HA functionality.
Since Apache Ignite is on the list of affected applications will there be a possibility to use hot-fixed Apache Ignite (that will be realesed soon)?
Kind Regards,
Rostislav Jirásek
VladimirN
24-Ruby II
(To:RosJir)
 Hi Rostislav,
1. "Log4j Security Vulnerability Response Center": https://www.ptc.com/en/documents/log4j
2. Try asking your question here - "Case Logger": https://support.ptc.com/apps/case_logger_viewer/cs/auth/ssl/log
VladimirN
24-Ruby II
(To:RosJir)
 Hi Rostislav,
slangley
(To:RosJir)
Hi @RosJir.
Hopefully, you found the answer to your question regarding vulnerability in the link provided by VladimirN.  In regard to using the hot-fixed Apache Ignite, it appears that it will work with ThingWorx 9.3.  If you are using an earlier version of ThingWorx, you will need to stay with what you have.
--Sharon
