Thingworx Java Edge SDK connection error
jnair1
Dear Thingworx Community members,
I am trying write a Thingworx Java Edge SDK example in an OSGi environment. My example is based on the Weather application given in the Thingworx academic resource page.
During the initial connection negotiations I am getting an error "Invalid Protocol Version".  Given below is the log:
8:33:22.481 [NettyClient-NIO-41] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=60
08:33:22.506 [NettyClient-NIO-41] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
08:33:22.507 [NettyClient-NIO-41] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=17
08:33:22.508 [NettyClient-NIO-41] ERROR c.t.c.c.c.n.ThingworxClientConnectionHandler - WebSocket error: Invalid Protocol Version [71], closing connection!
08:33:23.729 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
08:33:23.730 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: Am2302Thing, id: 0]. Attempting [re]connect...
08:33:23.730 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
08:33:23.731 [Client-EndpointMonitor-1] INFO  c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
08:33:24.746 [Client-EndpointMonitor-1] INFO  c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: true, is active: false]
08:33:24.747 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://192.168.0.12:8080/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
Does anybody have an idea what’s causing this error?
Any help would be appreciated.
Best Regards,
Jishnu
jnair1
(To:AdamR)
Hallo Adam,
The problem is resolved. The issue was with Netty which was missing some packages in the OSGi environment. After exposing the additional packages, its now working fine.
Jishnu
6 REPLIES 6
AdamR
(To:jnair1)
Jishnu,
On the Thingworx platform, is it setup to use SSL?  For the Java SDK you must use a secure connection (wss).
jnair1
(To:AdamR)
Hallo Adam,
Jishnu
ascotto
(To:jnair1)
Can you post your example of microservice?
jnair1
(To:ascotto)
My program was based on the Thingworx Weather App Example.
You can find it here:
http://www.thingworx.com/academic_content/r-pi-weather-app/
Best Regards,
Jishnu Nair
ascotto
(To:jnair1)
Thank you for the replay, I'm interested on how you did the bundle for OSGi because I have to add to a service I built.
Your example could save me a lot of time.
jnair1
(To:ascotto)
Hallo Alfredo,
I converted the Thingworx Java SDK to an OSGi bundle using Eclipse.
How to create Eclipse plugins from jars - Tutorial
JIshnu
