Dear Thingworx Community members,
I am trying write a Thingworx Java Edge SDK example in an OSGi environment. My example is based on the Weather application given in the Thingworx academic resource page.
During the initial connection negotiations I am getting an error "Invalid Protocol Version". Given below is the log:
8:33:22.481 [NettyClient-NIO-41] DEBUG i.n.h.c.h.w.WebSocket08FrameEncoder - Encoding WebSocket Frame opCode=2 length=60
08:33:22.506 [NettyClient-NIO-41] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame opCode=2
08:33:22.507 [NettyClient-NIO-41] DEBUG i.n.h.c.h.w.WebSocket08FrameDecoder - Decoding WebSocket Frame length=17
08:33:22.508 [NettyClient-NIO-41] ERROR c.t.c.c.c.n.ThingworxClientConnectionHandler - WebSocket error: Invalid Protocol Version [71], closing connection!
08:33:23.729 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints
08:33:23.730 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: Am2302Thing, id: 0]. Attempting [re]connect...
08:33:23.730 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0]
08:33:23.731 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1]
08:33:24.746 [Client-EndpointMonitor-1] INFO c.t.c.c.c.n.NettyClientConnectionFactory - forcing underlying tcp channel closed [is open: true, is active: false]
08:33:24.747 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://192.168.0.12:8080/Thingworx/WS] failed : timeout waiting for websocket handshake to complete
Does anybody have an idea what’s causing this error?
Any help would be appreciated.
Best Regards,
Jishnu
Hallo Adam,
The problem is resolved. The issue was with Netty which was missing some packages in the OSGi environment. After exposing the additional packages, its now working fine.
Jishnu
Jishnu,
On the Thingworx platform, is it setup to use SSL? For the Java SDK you must use a secure connection (wss).
Hallo Adam,
Jishnu
Can you post your example of microservice?
My program was based on the Thingworx Weather App Example.
You can find it here:
http://www.thingworx.com/academic_content/r-pi-weather-app/
Best Regards,
Jishnu Nair
Thank you for the replay, I'm interested on how you did the bundle for OSGi because I have to add to a service I built.
Your example could save me a lot of time.
Hallo Alfredo,
I converted the Thingworx Java SDK to an OSGi bundle using Eclipse.
How to create Eclipse plugins from jars - Tutorial
JIshnu
