Hi @NK_11392663 Can you check the below?
Hi @NK_11392663 Are you using connected mode? Can you share your application logs?
[L: ERROR] [O: E.c.q.l.c.Logger] [I: ] [U: Administrator] [S: ] [P: ] [T: http-nio-8080-exec-9] Was not able to complete metrics auto enrollment. Skipping Enrollment for opt out license.
this is the error i am getting
Hello @NK_11392663,
It looks like you have a response from a community member. If it helped to answer your question, please mark the reply as the Accepted Solution.
Abhi
