Hi guys,
I'm working with the Thingworx Remote Access Client and I want to connect this with TWX which is running on AWS.
When I start a connection via the RemoteAccessClientLinker-Widget the RA-Client starts and try to connect and timed out after few secondes with the error message:
Unable to connect to Thingworx; ensure platform is available at <xxx.xxx.xxx.xxx:443> and that proxy settings are correct
Last week I try the same with a PTC-Hosted Thingworx and everything works fine. On my AWS hosted Thingworx it will not connect. Strangely it works fine with the old Remote Access Widgets.
server.xml (without all comments)
<?xml version="1.0" encoding="UTF-8"?>
<Server port="8005" shutdown="SHUTDOWN">
<Listener className="org.apache.catalina.startup.VersionLoggerListener" />
<Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on" />
<Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener" />
<Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
<Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener" />
<GlobalNamingResources>
<Resource name="UserDatabase" auth="Container"
type="org.apache.catalina.UserDatabase"
description="User database that can be updated and saved"
factory="org.apache.catalina.users.MemoryUserDatabaseFactory"
pathname="conf/tomcat-users.xml" />
</GlobalNamingResources>
<Service name="Catalina">
<Connector port="8080"
protocol="org.apache.coyote.http11.Http11NioProtocol"
connectionTimeout="20000" />
<Connector port="443"
maxThreads="150"
SSLEnabled="true"
scheme="https"
secure="true"
keystoreFile="${user.home}/8.5.41/conf/.keystore"
keystorePass="KEYSTOREPASSWORD"
clientAuth="false"
sslProtocol="TLS" />
<Engine name="Catalina" defaultHost="localhost">
<Realm className="org.apache.catalina.realm.LockOutRealm">
<Realm className="org.apache.catalina.realm.UserDatabaseRealm"
resourceName="UserDatabase"/>
</Realm>
<Host name="localhost" appBase="webapps"
unpackWARs="true" autoDeploy="true">
<Valve className="org.apache.catalina.valves.AccessLogValve" directory="logs"
prefix="localhost_access_log" suffix=".txt"
pattern="%h %l %u %t "%r" %s %b" />
</Host>
</Engine>
</Service>
</Server>
config.json (on EMS-side)
"ws_servers": [{
"host": "xxx.xxx.xxx.xxx",
"port": 443
"appKey": "xxxxxxxxxxxxxxxxxxxxx",
"logger": {
"level": "INFO",
"publish_directory": "/microserver/logs",
"publish_level": "INFO",
"max_file_storage": 2000000,
"auto_flush": true
"http_server": {
"ssl": false,
"authenticate": false
"ws_connection": {
"encryption": "ssh"
"certificates": {
"validate": false,
"allow_self_signed": true
"tunnel": {
"buffer_size": 8192,
"read_timeout": 100,
"idle_timeout": 300000,
"max_concurrent": 4,
"verbose": false,
"duty_cycle": 100
"file": {
"max_file_size": 8000000000,
"virtual_dirs": [
{"other": "/microserver/other"},
{"tw": "/microserver/tw"},
{"updates": "/microserver/updates"}
"staging_dir": "/microserver/staging"
"auto_bind": [{
"name": "EMSBox"
So, I think I fixed the problem. I add a domain to my ec2 where thingworx is running. Than I generate a certificate from lets encrypt for this domain. Now its look like the client can connect to thingworx. I'm not hundred percentage sure because I get a new error message in remote client:
Platform websocket error encountered. (error: Error: Hostname/IP doesn't match certificate's altnames: "IP: xxx.xxx.xxx.xxx is not in the cert's list: ")
xxx.xxx.xxx.xxx = IP of EC2.
Hi @drichter.
Is the hosted ThingWorx instance the same version as that running in AWS? Is the old Remote Access client running on the same machine? This could be a firewall issue.
--Sharon
On AWS runs TWX 8.4.5-b102.
I try it with a other 8.4 Version (I'm not sure which exact version it was).
Actualy I use Version 8.5.0-b12.
I would rule out a firewall-problem, because with the old widget (with java starter stuff) works and this use port 443 too. And on AWS side port 443 is open.
Hi @drichter.
It sounds like the certificate that was generated was not issued with the name of the domain you are using to access your site.
--Sharon
I can fixed that issue today. The problem was todo with settings in TunnelSubsystem. I had there entered the IP address of my EC2 instance where TWX is running. But on EMS-side I used the domain-name.
So I change "Public host name used for tunnels" in TunnelSubsystem to the domain name too.
