Thingworx Scheduler to pull data from RestAPI Odata Windchill
danialdesa
Hi All,
Im having issue to schedule a service that will able to pull data from WRS odata windchill. While if im schedule postfress query it is working find. Please help me on this issue.
7 REPLIES 7
slangley
23-Emerald II
(To:danialdesa)
Hi @danialdesa
What errors are you getting?
--Sharon
danialdesa
(To:slangley)
HI @slangley ,
Here I attach the error and my setting on the thing that subscribe the scheduler.
slangley
23-Emerald II
(To:danialdesa)
Hi @danialdesa.
If you have resolved your issue with help from one of the previous responses, please mark the appropriate one as the Accepted Solution for the benefit of others in the community.
If you still have issues, please let us know.
--Sharon
BABA-SHYAM
(To:danialdesa)
When creating a sceduler make sure proper access control is given to the sceduler. For example, if the service needs a Admin access to execute so you need to give sceduler a Admin user which will run the server by proxy.
Regards
Shyam
danialdesa
(To:BABA-SHYAM)
Hi @BABA-SHYAM ,
I already try that, and still not working and for additional my instance is a SSO configuration, Do it will affected the scheduler?
BABA-SHYAM
(To:danialdesa)
I doubt that SSO will play any role. I haven't been much on SSO.
Regards
Shyam
BABA-SHYAM
(To:BABA-SHYAM)
Not sure if it will work, can you change "var fresult" to "var result" and not sure if $sign has something to do with the issue.
Regards
Shyam
