Thingworx Tab Widget does not display data in collection widget when placed in multiple tabs
Vishnu_K
In my mashup, there is a tab widget having 3 tabs. In the first 2 tabs, there is a collection widget, and it is binded to the output of the same service. On viewing the mashup, we can see data in the collection widget in the first tab but there is no data in the collection widget in the second tab. On changing the default tab value to second, then the data in the collection widget in the second tab is showing but in the first tab, data in the collection widget is not showing.
Vishnu_K
(To:PEHOWE)
The version is 8.5.4. By the way, the issue is resolved by putting the collection in the container.
Thank you @PEHOWE
3 REPLIES 3
@Vishnu_K ,
Tried a quick test case, I am not seeing the issue. Can you provide the ThingWorx Version and anything which would assist in creating a test case.
Peter
Vishnu_K
(To:PEHOWE)
Thank you @PEHOWE
slangley
23-Emerald II
(To:Vishnu_K)
Hi @Vishnu_K.
Since you found a solution, please mark your last reply as the Accepted Solution for the benefit of others with the same question.
Thank you for participating in our community!
--Sharon
