Thingworx User permission
borisov
Hello! Please, i need a help. When i create a new user, give hin permissions, but when i log in as this user, try to open a thing, i get the download line, what security log says attached as well as what applications log says.
Please create application key for that user in Thingworx > Security > Application Keys, add in User name Reference your user.
Best regards,
Raluca Edu
borisov
(To:raluca_edu)
Raluca, thank you for the answer!
I tried your suggestion, but problem is not solved yet, unfortunately.
jkaczynski
(To:borisov)
Hi @borisov,
It's very important to understand, that when you open a Thing in Composer, you need to have a visibility not only on this Thing, but also on Template. It's pretty logical, you cannot open General information page, where you have mentioned a Template, when you should not see this Template.
Please let me know if this helps.
BR,
JK.
