Hi There,
Is there any possibility to get web Push notification in Thing Worx? Any OOTB widget or extension available?
My Requirement is that when the user has minimized the Thingworx browser, then the user will be able to receive the notification, like Web Push Notification.
Thanks in advance
THanks @VV_10743662
Understood, so you're looking for browser notifications. Be careful, because in this scenario it is mandatory that the user first accepts the Notification permission.
The change in browser visibility (to detect minimize/maximize) can be intercepted with the Visibility API (works cross-browsers).
If you want to add Teams notifications (in the sense the user gets a message in Teams) you need to use Microsoft's Graph API to send such messages.
Overall speaking, this requires you to develop a Widget at least, to detect the browser changes and more important, to trigger notifications browser side. I think, but I did not use it before, that Firebase Cloud Messaging could be used for this. They have a Javascript SDK that you can package in your widget.
Note that for sending the actual notification, you can use the same API from the widget, but I would propose to implement the sending in the ThingWorx server, so that you can trigger notifications also from the server in the future (not only from the widget).
Similar discussion - "ThingWorx Website Push Notifications": https://community.ptc.com/t5/ThingWorx-Developers/ThingWorx-Website-Push-Notifications/td-p/526805
Hi @VladimirN
I have checked this post and the extension mentioned is not available in the marketplace when I checked. If you know the extension is available
can you share the name and link.
Try also sending a request via the form: https://www.ptc.com/en/products/thingworx/contact-us
Hi @VV_10743662
I have two questions:
1. Is the requirement that the same user that minimized browser will receive that notification? This feels a bit strange, tbh, especially if you're the same user.
Or another user will receive that notification?
2. Also, what type of notifications you're looking to get? There are Windows notifications, browser notifications (which require first the user to allow notifications, to which the user can just say no), Teams notifications (user can be notified via a Message). I imagine you're looking for browser notifications, correct?
>> Requirement is for same user to receive notification when he is doing some other task and Thing Worx Browser window is minimized, something occur then the browser notification should be received.
Something similar to like when MS Teams we use on browser then browser will send notification of someone's messages.
Yes, I am looking for the Browser notifications and a way how to send notification to MS teams also.
THanks @VV_10743662
Thanks @VladimirRosu
I was going to use the Microsoft graph API, thanks for confirming it. and will check the Firebase cloud Messaging.
HI @VV_10743662
For the benefit of others, if any of the replies above makes most sense for you, can you mark them by clicking on "Accept as Solution"?
Thank you!
