Thingworx composer stuck on loading when entering design mode for mashup
RH_9721753
3-Newcomer
when i use chrome , chose Design table ,it show none, and what is error?  it make me very uncomfortable,
6 REPLIES 6
Hello @RH_9721753
As per the screenshot shared by you it is still loading. So can you please check logs under monitoring section for any possible errors?
slangley
23-Emerald II
(To:RH_9721753)
Hi @RH_9721753.
This issue can occur if you have installed an incompatible extension.  What extensions have you installed?  The fix is to remove the extension in question.
--Sharon
I think you are a company with good service, and your reply on this issue is really timely. I have found the reason for my problem, which is that I installed it on the Server system, and it runs very well on Win10.
slangley
23-Emerald II
(To:RH_9721753)
Hi @RH_9721753.
You stated you installed on the Server system but when installing on Windows 10 it worked.  What version of Windows did you initially install on?
--Sharon
Windows Server 2016
slangley
23-Emerald II
(To:RH_9721753)
Hi @RH_9721753.
Windows Server 2016 is supported.  Here is a link to the system requirements for ThingWorx 9.0 (not sure which version you are running).
--Sharon
