Thingworx custom Authenticator extension not working
vtayal
I am trying to customise the Thingworx authentication flow by developing Authenticator extension .
I am trying to login into Thingworx by hitting url like <http://localhost:8080/Thingworx/Home?username="Administrator">   instead of login through Thingworx login page. But when i hit this url , i am getting error as "com.thingworx.common.exceptions.InvalidRequestException: Authentication failed: Please make sure the credentials are correct." in application logs.
Below is my code of "authenticate" method of my Authenticator extension:
@Override
public void authenticate(HttpServletRequest httpRequest, HttpServletResponse httpResponse)
throws AuthenticatorException {
     try {
          String user= httpRequest.getParameter("username");
          AuthenticationUtilities.validateEnabledThingworxUser(user);
          this.setCredentials(user);
          } catch (Exception e) {
               this.setRequiresChallenge(false);
               throw new AuthenticatorException("Provided username is not valid, " + ADICognitoAuthenticator.class.getSimpleName() + " failed to auto login!");
Is it possible to login into Thingworx without giving password via custom Authenticator extension?
vtayal
(To:vtayal)
I got the soution:
add
AuthenticationUtilities.getSecurityMonitorThing().fireSuccessfulLoginEvent(user,
SharedConstants.EMPTY_STRING); after this.setCredentials(user);
This works for me
AdamR
(To:vtayal)
This would be possible but you would need to hardcode a password or application key into the Authenticator.  It is not possible to login without one of those being passed.
vtayal
(To:vtayal)
Thanks Adam for your reply...
Actually, i was taking reference from "Thingworx custom AutoAuth · GitHub"  example where it works with that flow. I thought of validating credentiials outside Thingworx and then redirect to Thingworx composer with the username which is already enabled into Thingworx.
vtayal
(To:vtayal)
I got the soution:
add
This works for me
