I have successfully installed thingworx analytic s on one virtual machine and data connector on another virtual machine on the same virtual box.when
1.I try to access analytic by http://192.168.56.102:8080/1.0/about/versioninfo i get proper response of analytic server version 7.4
but when i try to to do the same for http://192.168.56.104:8080/1.0/about/versioninfo for dataconnetor it doesnt gives a responese.what could be the reason ,
2.Also .i have my PostgreSQL server installed in the analytic virtual machine and not on the data connector virtual machine
I have set the following parameters as follows
org.postgresql.Driver
jdbc:postgresql://192.168.56.102:5432/dataconnect
dcuser
password
is that OK
and what is the data connect.transfer.uri parameter and what we need to specify for that
3. How to make a link between the thingworx repositories between thingworx foundation which is host of the virtual machine setup,where should i make those folders in the data connector ,in order to integrate with the thingworx foundation
Warm Regards
Shubham
It seems we have several duplicated threads with the exact same content.
This will be dealt with in Thignworx dataconnector installation
