I have installed Thingworx 8.3 on an ubuntu 16.04 machine and faced some licensing issue ( same as this topic ).
I have finally solved the problem, but before reading the topic, I have re-install Thingworx and database many times, it shows different device id in licenseRequestFile.txt file so I downloaded multiple license file, does it use our quota? If that's the case, how can I do to remove them?
Hi @ivan_tsai.
I checked around and found that you should be ok.
--Sharon
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
Hi @ivan_tsai.
--Sharon
