Thingworx how to cancel autofocus filter input in dropdown widget
  • October 30, 2021
  • 2 replies
  • 2306 views
if you enable filter of dropdown widget, while click dropdown widget, filter input will auto focus in opened popup, How can I ban this autofocus action? I don't need autofocus in my scenario.
If possible, can you share the screenshot of the same?
Here is a quote from the following article - "Focus style cannot be disabled in ThingWorx 9.0.0" (link: https://www.ptc.com/en/support/article/CS329306 😞 "Workaround to disable the default focus style is to use the following custom CSS"
ptcs-focus-overlay {
visibility: hidden;
.ptcs-wrapper:not([no-wc-style]):focus:not(.dummy):not(.dummy):not(.dummy) {
box-shadow: none;
Also, previously there were the following questions, the answers to which may also be useful:
https://community.ptc.com/t5/ThingWorx-Developers/Force-focus-to-a-textbox/td-p/501391
https://community.ptc.com/t5/ThingWorx-Developers/Text-Field-widget-not-focusing/td-p/676141
https://community.ptc.com/t5/ThingWorx-Developers/Set-focus-on-textbox/td-p/691461
Blake_Xie13-AquamarineAuthor
very thank you VladimirN, it seems not to work for input filter of dropdown widget .
If you add the below under Custom CSS tab of TWX Mashup where Dropdown is added, you should be able to get rid of Default Blue border focus. I verified this on TWX 9.2, what is your version of TWX?
visibility: hidden;
box-shadow: none;
