Thingworx mashup widget horizontal slider: input array of values
SBO
I need to input an array of values in the horizontal slider widget, instead of defining min/max/step.
How can I achieve that ?
Thx.
PaiChung
22-Sapphire I
(To:SBO)
Ahh sorry, that isn't possible
4 REPLIES 4
PaiChung
22-Sapphire I
(To:SBO)
A slider will not accept an 'array' or infotable directly.
If you are outputting an infotable and it is a single row, you can expand Data and take the individual values and bind those to min/max/value
If you are using a multirow infotable, you would use selected row(s) in a similar way
Selecting from Data (All Data) it always provides the 1st row.
Else you'd have to return three individual values, unless these values are properties, then you can also use getproperties
SBO
(To:PaiChung)
it's not about the infotable data input manipulation, I am referring to making the slider allow selectable values only those that I choose.
Example:
currently the slider widget sets min/max/step (1/10/1) and the selectable values will be 1,2,3,4,5,6,7,8,9,10
I need to have the slider offer the user only the values 1,4,6,7,10
PaiChung
22-Sapphire I
(To:SBO)
slangley
(To:SBO)
Hi @SBO.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Thank you for participating in our community!
--Sharon
