Thingworx projects
SOLVED
Regular Member
Thingworx projects
Hi, i'm still new to thingworx.
Is there a way to export the entire project and import it back safely without loosing any of the connections.
Thanks in advance.
Re: Thingworx projects
@Jimmy4
Thank you for opening this post on community. Yes you can export a complete project in ThingWorx.
Make sure each and every entity has a the project tag which you have created.
Same Project you can import later in the same server or any other server. Version conflict may be there if you will try to import in any other major version.
Mohit
@Jimmy4
Mohit
Hi @Jimmy4.
If the previous post answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for participating in our community!
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
