Hi, i'm still new to thingworx.
Is there a way to export the entire project and import it back safely without loosing any of the connections.
Thanks in advance.
Thank you for opening this post on community. Yes you can export a complete project in ThingWorx.
Make sure each and every entity has a the project tag which you have created.
Same Project you can import later in the same server or any other server. Version conflict may be there if you will try to import in any other major version.
Mohit
Mohit
Hi @Jimmy4.
If the previous post answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for participating in our community!
Regards.
--Sharon
